Hello. The clock display on my range is very dim, no fault codes showing. The oven will turn on, but the up arrow to adjust the temp doesn't work. The oven will only heat to about 325 degrees. After searching the forums I feel pretty sure it's the Control Assembly and I've ordered it here online. But I haven't seen any tips on replacement. It looks like the cooktop will need to come off and I'm just not sure how to. Are there any manuals online that I could glean some information from? Any help would be greatly appreciated.
