ender7
#1 Posted : Saturday, June 20, 2009 8:06:32 PM(UTC)
ender7
Hello and thank you.
This Maytag washer squeals in spin cycle and you can smell something burning during the spin cycle (pretty obviously one of the belts).
Of course, I suspect something to do with the belt(s). The belts seem very loose. I know that the pump belt is supposed to be loose with no more than 1/4" inch space when pinching the belt.
What I am wondering though, is the main drive belt able to stretch so much? The motor has two tension springs, could they need replacing? Or is just a new belt in order?
When in the spin cyle, I can physically pull on the motor to tension it, the spin works just fine.
Belts, and springs? Or just belt?
Any other hints/tips for installation? Much appreciated! Very low on cash... I'll spare you the details.
Thanks much!
#2 Posted : Sunday, June 21, 2009 5:41:17 AM(UTC)
Clean and oil the rollers under the motor mount, should fix the problem. Also check for a busted spring.
