DawnAnn
#1 Posted : Saturday, June 20, 2009 12:42:27 PM(UTC)
DawnAnn
I just bought a house that has the above oven in it.
The digital display does not work although some of the touch pads do work. The Baking/Broiling etc do not work.
If I buy the control board and replace it, will that solve the problems and how hard is it to replace. From the diagram it looks like it's just a couple of ribbon connections.
Dan O.
#2 Posted : Saturday, June 20, 2009 2:21:20 PM(UTC)
Dan O.
You might have several problems, the electronic control and also the keypad. I don't know that just the control panel display failing would prevent some of the keyboard keys from functioning.
LINK > Jenn-Air WW27430W Electronic Control
LINK > Jenn-Air WW27430W Control Keypad
I would think replacing the control should correct the display problem.
Once you get to it, it shouldn't be that difficult. I do not know exactly what is involved in accessing it on your model although that too isn't usually that difficult on most models.
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
DawnAnn
#3 Posted : Wednesday, June 24, 2009 9:07:19 AM(UTC)
DawnAnn
Thank you so much for your help. I had read that the lack of display in the control panel is quite a common problem with the jennair ww27430w. The guy on the Jennair help line told me that these ovens only have a life span of 10 to 13 years and told me that I would have to spend $3000 to buy a new one. This was very easy to fix and it only cost $180..or so. Now I just need to find the owners manual online. Thanks again.
Dan O.
#4 Posted : Wednesday, June 24, 2009 10:48:14 AM(UTC)
Dan O.
It is a common failure on all brands and models of appliances that use such controls... unfortunately. :rolleyes:
LINK > Jenn-Air WW27430W Product Literature
Glad to hear it. Thanks for the follow up.
Dan O.
=D~~~~~~
DawnAnn
#5 Posted : Wednesday, June 24, 2009 11:45:22 AM(UTC)
DawnAnn
I had been searching for that for hours and couldn't find it. One more thing, is there a way to replace the facade of that oven with Stainless Steel?
Dan O.
#6 Posted : Wednesday, June 24, 2009 12:00:18 PM(UTC)
Dan O.
AFAIK that oven model was never available in stainless steel so such parts would not be available, no.
Dan O.
=D~~~~~~
