merlisak
#1 Posted : Saturday, June 13, 2009 9:06:43 PM(UTC)
merlisak
The washer continues to fill the water overflows
sidfink43
#2 Posted : Monday, June 15, 2009 9:27:59 AM(UTC)
sidfink43
H Merlisak
If you washer is less than 1 year old it should have factory warranty and you should get warranty service to fix it.
In general, though, if the water will not shut off when the machine is turned off, the problem is in the inlet valves, if it will shut off when the machine shuts off the problem is in the water level system, either the switch or the mechanism that tells the washer the tub is filled.
If you need more help, please post a model number.
Thanks and good luck.
Washer overflows (Washer Repair)
by pecosb1 8/19/2015 7:25:20 PM(UTC)
Washer overflows - water level switch replaced - did not help (Washer Repair)
by qeisus64 12/12/2014 2:15:59 PM(UTC)
GE washer overflows after agitation unless extra small load WCXR1070TAWW (Washer Repair)
by Larry75243 9/16/2013 11:10:36 AM(UTC)
washer overflows on xlarge load only (Washer Repair)
by FRVMAN 9/1/2013 6:33:24 AM(UTC)
Kenmore Dishwasher overflows to the floor (Dishwasher Repair)
by goingjumping 2/17/2013 3:03:47 PM(UTC)
washer overflows and unbalance load displayed (Washer Repair)
by allen9258 1/27/2013 7:41:58 AM(UTC)
Maytag Washer overflows on rinse only (Washer Repair)
by basgetar 5/9/2012 5:40:29 PM(UTC)
Washer Overflows Except with Cold Water (Washer Repair)
by jimponti 1/15/2012 5:43:01 PM(UTC)
Dishwasher overflows when using sink (Dishwasher Repair)
by Phil69 12/30/2011 3:51:49 PM(UTC)
Maytag washer overflows during agitation (Washer Repair)
by TexasTaylors 5/28/2011 8:18:42 PM(UTC)
Washer overflows AFTER 1st agitation (Washer Repair)
by Huff360 10/4/2010 6:36:29 AM(UTC)
GE Washer Overflows (Washer Repair)
by vbiondillo@norhill.net 8/3/2010 12:53:03 PM(UTC)
Washer overflows - sometimes (Washer Repair)
by psunittanylion 7/6/2010 9:48:24 AM(UTC)
Washer overflows when set at large load (Washer Repair)
by Victor Scott 6/7/2010 9:46:52 AM(UTC)
Kenmore washer overflows on rinse cycle (Washer Repair)
by montani 5/18/2010 12:00:23 PM(UTC)
