pattylyn44
#1 Posted : Saturday, June 13, 2009 12:02:56 PM(UTC)
pattylyn44
First my range had the electronic sparks would spark with everything turned off. So we replaced the spark modulator. Then the control board wouldn't come on so we replaced it. Now my oven won't come on. I have been trying to fine a wiring diagram for it so we can make sure we have the wires in the right place. Do you know where I can find one. I have contacted GE over a week ago and they still haven't emailed me one.
Dan O.
#2 Posted : Sunday, June 14, 2009 2:53:41 AM(UTC)
Dan O.
Quote:
Do you know where I can find [a wiring diagram].
Probably only from GE... if the one that should have been in or on the appliance when it left the factory is missing.
Some things take time with GE although you might want to check with them again to make sure they can even provide a replacement. They are not always available. :eek:
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
kayakcrzy
#3 Posted : Sunday, June 14, 2009 5:19:13 AM(UTC)
kayakcrzy
GE is worthless!!!!!!!!!! Let me ask you this. You have a bake ignitor and a broiler ignitor. Check and see if either one comes on. If either one does not work, then it will be a control issue. It is a double gas valve, so it is highly unlikely that both sides of the valve are bad. Report back to me, if the either ignitor comes on, because it could just be an ignitor, or in the process of you replacing the control board, something could not be right there. Tom www.aplianceeducator.com
pattylyn44
#4 Posted : Sunday, June 14, 2009 5:38:07 AM(UTC)
pattylyn44
The broiler does light and come on. Now it sounds like one of the lighters is trying to light with nothing turned on. I'll get with ge again to see if they have found the diagram yet. Do you think that maybe the ignitor for the the oven has gone bad?
kayakcrzy
#5 Posted : Sunday, June 14, 2009 5:46:19 AM(UTC)
kayakcrzy
yes i do. it is a common problem. by the lighters, i quess you are talking about the top burner ignitor? tom
pattylyn44
#6 Posted : Sunday, June 14, 2009 6:17:49 AM(UTC)
pattylyn44
not sure if it is a top. About every thirty seconds you can hear a noise that sounds like one click. We put a new spark module in and it stoped for two days now it is back. We put a new control panel in and the lower part of oven is the only think that won't work. The broil and the self clean both come on but in self clean the lower part won't come on. The range doesn't give me any kind of code so I can look up that problem.
Amana oven won't light (Oven Repair (including Ranges and Cooktops))
by rope13 1/10/2017 3:55:40 PM(UTC)
Help, my gas oven won't light..... (Oven Repair (including Ranges and Cooktops))
by lharrell79 3/17/2016 10:13:10 AM(UTC)
Oven won't light, hear click(s), no gas smell (Oven Repair (including Ranges and Cooktops))
by gizmodyne 4/26/2015 6:36:01 AM(UTC)
Kitchenaid Gas Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by Chris Ricc 1/7/2015 8:13:37 PM(UTC)
Oven won't light (Oven Repair (including Ranges and Cooktops))
by davidr222 7/31/2014 7:01:18 AM(UTC)
Magic Chef Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by miisu 1/21/2014 4:55:33 PM(UTC)
Oven won't light; shuts off with F2 Error during pre heat (Oven Repair (including Ranges and Cooktops))
by MaxRock 11/21/2013 2:12:32 PM(UTC)
Whirlpool Oven Won't light (Oven Repair (including Ranges and Cooktops))
by klucich 5/13/2013 4:36:10 AM(UTC)
Frigidaire oven won't light (Oven Repair (including Ranges and Cooktops))
by baltojeff 12/7/2012 6:58:35 AM(UTC)
Roper Oven won't light (Oven Repair (including Ranges and Cooktops))
by LoneMedic 11/9/2012 10:15:54 AM(UTC)
gas broiler and oven won't light (Oven Repair (including Ranges and Cooktops))
by rickric 8/27/2012 4:16:55 PM(UTC)
GE Profile, oven won't light (Oven Repair (including Ranges and Cooktops))
by Buggus 8/1/2012 4:05:34 AM(UTC)
by gregew 7/10/2012 7:47:10 AM(UTC)
by fml421 6/3/2012 1:51:47 PM(UTC)
by jlgilbert 5/30/2012 11:13:47 AM(UTC)
