DAVEA
#1 Posted : Monday, November 28, 2011 9:36:36 AM(UTC)
DAVEA
oven will not get hot enough, takes to long to bake, already replaced oven element. No codes
#2 Posted : Monday, November 28, 2011 1:28:59 PM(UTC)
Place an oven thermometer in the middle of the oven cavity. Set the oven for Bake at 350°F and start it. Wait until it's preheated (should beep). Give it 15 minutes more. Open the oven door and read the thermometer. Post the results.
- The oven thermometer Part number: AP4022061
P.S. The model number you posted is incomplete.
DAVEA
#3 Posted : Thursday, December 1, 2011 2:41:43 PM(UTC)
DAVEA
Hay Gene ,
I did what you said with the oven thermometer in the oven set at 350 degrees for 15 min. Temperature was 250 on thermometer:rolleyes:. 100 degrees to low. This is an electric whirlpool GR448LXPB0 ser# RR4115706. Like I mention before I already replaced the lower element. I'm leaning towards the oven temp sensor??
Your help is greatly appreciated.
Dave
#4 Posted : Thursday, December 1, 2011 3:57:00 PM(UTC)
Hi Dave,
Check the oven sensor for continuity. The normal reading should be about 1100 Ohms at the room temperature. If the reading is correct, replace the control board.
- The oven sensor Part number: AP4326911
