mauricimo
#1 Posted : Sunday, May 31, 2009 6:12:56 AM(UTC)
mauricimo
all top gas burners work nomally, but oven will no light. heat igniter is red hot but flame will not come on.:confused:
Dan O.
#2 Posted : Monday, June 1, 2009 1:23:38 PM(UTC)
Dan O.
Quote:
oven igniter is red hot but flame will not come on
That could be caused by a defective ignitor or oven gas valve. And yes, an ignitor can glow and still be defective.
LINK > Frigidaire FGF316ASB Oven Ignitor
LINK > FGF316ASB Oven Gas Valve
The only way to tell for sure which is responsible is to measure the amperage draw of the ignitor circuit. With the ignitor used on your model that amperage draw should be 3.2 to 3.6 amps. If more or less, the ignitor would be defective. If it was drawing within those tolerances the oven valve would be assumed to be the problem instead. There is no other voltage or resistance test that will determine the cause of such a symptom.
The oven ignitor on such a system is the most common (70-80%) troublemaker. :rolleyes:
JMO
Dan O.
www.Appliance411.com
The Appliance Information Site
=D~~~~~~
Help, my gas oven won't light..... (Oven Repair (including Ranges and Cooktops))
by lharrell79 3/17/2016 10:13:10 AM(UTC)
Kitchenaid Gas Oven Won't Light (Oven Repair (including Ranges and Cooktops))
by Chris Ricc 1/7/2015 8:13:37 PM(UTC)
GE gas oven won't light -- igniter works (Oven Repair (including Ranges and Cooktops))
by markdraper 5/26/2011 10:37:41 AM(UTC)
Geneal Electric XL44 gas oven won't light (Oven Repair (including Ranges and Cooktops))
by watchwoman1950_2005 12/26/2010 11:26:18 AM(UTC)
by jennblueskies 5/13/2010 8:26:01 AM(UTC)
Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by homeboy 1/30/2010 1:50:06 PM(UTC)
Tappan Gas oven won't light (Oven Repair (including Ranges and Cooktops))
by ghengiskenn 9/29/2009 5:26:08 PM(UTC)
Gas oven won't light... (Oven Repair (including Ranges and Cooktops))
by johnny63 12/23/2008 4:19:21 PM(UTC)
Gas Oven won't light (Oven Repair (including Ranges and Cooktops))
by LQQKING4U 12/14/2008 3:09:46 PM(UTC)
Gas oven won't light/goes out (Oven Repair (including Ranges and Cooktops))
by jgbradley 11/29/2008 6:06:57 AM(UTC)
by tpon 5/14/2008 3:54:37 PM(UTC)
Magic Chef gas oven won't light (Oven Repair (including Ranges and Cooktops))
by koohgar 7/23/2007 5:57:24 PM(UTC)
