will not spin in any mode
If this is acompanied by motor noise and possibly a screeching belt, the problem is likely to be a worn thrust bearing. It's responsible for releasing the brake for spinning. If no motor noise is heard at all, you probably have a bad lid switch. Part number: AP4029156
