This is a black Whirlpool double oven, top oven is self-cleaning. Every so often the control display goes blank and it beeps a few times. When it does this the buttons will make a beep, and the light will come on, but when I push start it beeps 3 or 4 times and...nothing. Sometimes I come home and the clock and display are on and the oven will work normally. Sometimes it will finish a job and sometimes it quits in process. I believe it can be repaired for less $ than replacemet and it s in perfect shape otherwise. Can you advise?
Additional information: The oven display came back on; the clock or green portion displays F2; the orange display to the upper left displays E6. Originally Posted by: Wascator This is a black Whirlpool double oven, top oven is self-cleaning. Every so often the control display goes blank and it beeps a few times. When it does this the buttons will make a beep, and the light will come on, but when I push start it beeps 3 or 4 times and...nothing. Sometimes I come home and the clock and display are on and the oven will work normally. Sometimes it will finish a job and sometimes it quits in process. I believe it can be repaired for less $ than replacemet and it s in perfect shape otherwise. Can you advise?
Ok, I found enough info in reading the other answers: I will try unplugging and reattaching the harness. if I can get the control panel apart. Can anyone assist with that?
