las1234
#1 Posted : Wednesday, November 9, 2011 4:24:44 PM(UTC)
las1234
I have a GE model GSD5360F01SS. Last week I noticed some hard black pieces in the bottom. I it looked as though it were some sort of gasket at the very bottom of the door between the door panel & the bottom panel. Today when I received a part & took the door apart I found that the Mastic door panel AP3964102 had literally slipped down the door and that is what is coming apart inside of the dishwasher.
I see that I can order & replace that part, however could that coming down into the dishwasher be what caused the leak? If not, then do I need to replace the door gasket or is there something else I can check before spending money on other parts?
Bosch Dishwasher Leaking into base (Dishwasher Repair)
by Canadianice 4/12/2018 8:18:35 AM(UTC)
Dishwasher leaking underneath [PHOTOS] (Dishwasher Repair)
by jd514 1/6/2018 11:16:52 AM(UTC)
Dishwasher leak at float (Dishwasher Repair)
by warrenmott1 1/2/2018 12:37:31 PM(UTC)
Kemore Dishwasher Leak (Dishwasher Repair)
by Chevyman22360 7/19/2017 11:40:09 AM(UTC)
dishwasher leak at door (Dishwasher Repair)
by rpantel 4/26/2017 12:31:18 PM(UTC)
Kitchenaid dishwasher leaking under door (Dishwasher Repair)
by chasethedream 1/1/2017 8:30:50 AM(UTC)
Dishwasher leaking from motor area (Dishwasher Repair)
by jay143 11/1/2016 12:20:29 PM(UTC)
Dishwasher Leaking (Dishwasher Repair)
by alanwoodbury 9/26/2016 10:47:47 AM(UTC)
whirlpool dishwasher leaking from door (Dishwasher Repair)
by pburd89 2/19/2016 1:36:17 PM(UTC)
Kitchenaid Dishwasher Leaks at Float (Dishwasher Repair)
by macd2x 11/8/2015 7:29:26 AM(UTC)
Kitchenaid dishwasher leaking (Dishwasher Repair)
by steve80124 9/21/2015 2:15:04 PM(UTC)
Dishwasher leaks front door (Dishwasher Repair)
by kbratto 8/26/2015 9:53:11 AM(UTC)
dishwasher leak under motor area (Dishwasher Repair)
by rheare 8/22/2015 11:52:33 AM(UTC)
dishwasher leak. What's this part? (Dishwasher Repair)
by pman6 7/2/2015 4:16:27 PM(UTC)
dishwasher leak when starting cycle. Drain pipe? (Dishwasher Repair)
by pman6 7/1/2015 12:16:44 PM(UTC)
