Hello - I need the Electric thermostat Part Number: AP4324689 replaced. Is it complex or should I engage a repair person?
This part is not too difficult to replace yourself. Lift up the top panel, push each of the top support rods (#115 on the diagram) toward the control panel to release them for the slots. Release the top panel hinges and put the panel aside. Remove the burners. Unscrew all screws around the burner box (#9 on the diagram). Remove the burner box and put it aside. Open the oven door, remove the thermostat sensing bulb from the supports and carefully pull it through the hole on top. Remove the wires from the old thermostat. Remove the screws holding the thermostat. Assemble in reversing order. Here are the breakdown diagrams and Replacement parts for GE JGBC20BEA4WH | AppliancePartsPros.comGene.
