joanmaryellen1
#1 Posted : Sunday, May 17, 2009 7:39:33 AM(UTC)
joanmaryellen1
i don;t know if my first message went through so here i go again I purchased a water level switch part #AP2045895 is there an adjustment screw? it is not working.
applianceman
#2 Posted : Sunday, May 17, 2009 1:45:56 PM(UTC)
applianceman
[FONT='Times New Roman']No, there is not adjustment on this switch. Was you original problem washer overfilling? If so the problem is that the tube that runs from the water level control to the tub is stopped up. To check this remove the front and look at the left-hand side of the tub you should see the tube remove it. Look in the end of the tube to see it is stopped up. If it is you should be able to clean it out with a toothpick. Clothes Washer Repair Guide[/FONT]
joanmaryellen1
#3 Posted : Monday, May 18, 2009 3:11:23 AM(UTC)
joanmaryellen1
yes it would keep filling up. when the repair man came he blew into the tube and it worked for one wash but not rinse cycle
Water level switch and something else maybe? (Washer Repair)
by tomsteve 2/19/2015 1:11:10 PM(UTC)
Washer overflows - water level switch replaced - did not help (Washer Repair)
by qeisus64 12/12/2014 2:15:59 PM(UTC)
Water still not stopping after water level switch replaced (Washer Repair)
by LIsa60 5/19/2014 5:33:24 AM(UTC)
GE Washer won't stop filling even after replacing Water Level Switch (Washer Repair)
by ctvquach 1/12/2014 4:33:29 PM(UTC)
Rinse - low water level - 2 Water Level Switches... (Washer Repair)
by Aleste 1/25/2013 4:20:37 AM(UTC)
Replacing water level switch (Washer Repair)
by Socalguy84 11/21/2012 8:07:56 AM(UTC)
by dellmack 8/28/2012 7:19:10 PM(UTC)
Two water level switches bad in 12 months? (Washer Repair)
by jfwilliams3 7/26/2011 8:35:32 PM(UTC)
installing water level switch (Washer Repair)
by chrisjay 3/4/2011 5:55:11 AM(UTC)
by bigdanallan 1/20/2011 7:42:20 PM(UTC)
Whirlpool Calypso Water Level Switch (Washer Repair)
by diyhelp 12/20/2010 6:14:21 AM(UTC)
by bowerman 11/2/2010 6:19:03 PM(UTC)
washer---water level switch (Washer Repair)
by brian_b@mail.com 10/26/2010 12:22:27 PM(UTC)
repairing a water level switch (Washer Repair)
by repairman756 1/10/2010 11:53:05 AM(UTC)
how do you test water level switch (Washer Repair)
by ldutton 10/11/2009 7:04:15 PM(UTC)
