mdfixer
#1 Posted : Wednesday, November 2, 2011 2:24:57 PM(UTC)
mdfixer
Roper 4440VQ1 will not start. I followed advice on this site and tested the continuity of the termal fuse, starter swicth, door switch and all were fine. I did not see instructions on how to test the timer?? Other than this, what else is there for me to test??
#2 Posted : Thursday, November 3, 2011 1:50:03 AM(UTC)
Replacement parts for WHIRLPOOL RED4440VQ1 29"ELECTRIC DRYER | AppliancePartsPros.com
To check the timer set the timer mid scale air only, this should disconnect the heating coil so it does not confuse your readings.
Unplug the unit.
Use the most sensitive scale on your meter.
Disconnect the wire/wires from C on the timer and measure across C to B.
Should be 0 ohms.
But before doing the above I would check the power.
Try flipping the breaker off/on slowly a couple times.
Sometimes you can loose half the line without actually tripping the breaker.
If this does nothing, check the voltage at the plug
L1 to L2 should be 240 volts
If OK
If OK
File Attachment(s):
RED4440.pdf (182kb) downloaded 8 time(s).
You cannot view/download attachments. Try to login or register.
mdfixer
#3 Posted : Thursday, November 3, 2011 11:22:10 AM(UTC)
mdfixer
Originally Posted by: denman Go to Quoted Post
Unplug the unit.
Should be 0 ohms.
If OK
If OK
Thanks for the replay. I know it is not the power source.
I set the timer to No heat fluff for 10 mins, unplugged the unit and disconnected the wire harness from ABCH leaving the other two harnesses connected. My meter showed no continuty between C and B. Regarless of which ohms setting I put the meter on, it read "1". I know the meter is working fine. Does this mean the timer is bad?
#4 Posted : Thursday, November 3, 2011 12:43:27 PM(UTC)
Yes I would agree with you that the timer is toast.
C/B contacts have to close for the motor to run.
mdfixer
#5 Posted : Thursday, November 3, 2011 12:50:56 PM(UTC)
mdfixer
New Information: When I unmounted the timer box I could here a small plastic part shaking around inside. I took the timer box apart and found the bottom ring that activates the switches was no longer mounted to the stem. I don't suppose it is possible to order just that small plastic ring that was light brown in color instead of a new timer for $78??
#6 Posted : Thursday, November 3, 2011 4:33:32 PM(UTC)
No you cannot get timer internal parts.
Roper Dryer: won't start, need help! (Dryer Repair)
by FerociousBeast 1/4/2017 5:45:40 PM(UTC)
Whirlpool Roper dryer timer (Dryer Repair)
by kparker1028 1/2/2017 9:15:02 AM(UTC)
Roper dryer not starting. (Dryer Repair)
by tekgeek 8/24/2016 7:57:05 PM(UTC)
Roper Dryer wont start. Not sure of the problem. (Dryer Repair)
by roadkill721 3/18/2016 4:39:05 PM(UTC)
Roper Dryer Stops Mid Cycle (Dryer Repair)
by bradford0113 1/26/2016 6:08:16 AM(UTC)
Roper dryer heating problems (Dryer Repair)
by laurencp72 1/19/2016 4:58:28 PM(UTC)
Whirpool Roper Dryer heat but doesn't spin (Dryer Repair)
by Kjeffrey02 1/2/2016 12:25:54 PM(UTC)
roper dryer heats but timer will not advance (Dryer Repair)
by ironhead1969 11/10/2015 9:32:58 AM(UTC)
Roper Dryer not drying (Dryer Repair)
by fhorta 11/3/2015 5:28:30 AM(UTC)
Auto sense dry roper dryer pops fuse dial does not advance (Dryer Repair)
by Chuckpie85 9/11/2015 4:59:42 PM(UTC)
roper dryer (Dryer Repair)
by smoke-71 3/3/2015 3:56:21 AM(UTC)
Roper Dryer stops working, then heater runs in all cycles including no heat. (Dryer Repair)
by econobiker 1/7/2015 8:50:40 AM(UTC)
roper dryer not heating (Dryer Repair)
by JONCNC1976 1/6/2015 7:05:49 AM(UTC)
roper dryer no heat (Dryer Repair)
by chuck vaughn 12/1/2014 1:35:50 PM(UTC)
Roper dryer only dries in timed mode (Dryer Repair)
by dmpsqrd 8/22/2014 11:24:59 AM(UTC)
