I Recently Replaced The Gas Valve On My Range After Seeing Other Post On Ovens Not Lighting Up. On All The Post That I Read, The Cause Was Said To Be A Defective Gas Module. I Replaced The Module And The Oven Is Still Not Working. The Gas Comes On, But There Is No Spark To Lite The Gas. The Ignitor Works On The Stove, But Not In The Oven. The Broiler Does Not Ignite Either. Correction, Once In While It Does Ignite, But Then The Oven Does Not Stay Heated Because The Igniter Fails To Light The Gas During The Cycle. Does It Sound Like A Bad Igniter Module? I Appreciate Your Help.
