My Frigadarie stopped dispensing cubes and onyl dispenses crushed ice even on the cice cube setting. Any thoughts? I emptied the ice cube bin already, but that did not work.
Thanks.
You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. Post your model number for diagrams of parts. Model Number Locator
Originally Posted by: woodchuckie You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. Post your model number for diagrams of parts. Model Number Locator What does the solenoid look like and where typically is it located? Thanks!
Originally Posted by: woodchuckie You have a solenoid switch which switches the dispenser back and forth from crushed to cube. It could be stuck or not working or the parts connecting it could be disconnected or broken. You will have to observe to see if any parts are moving and if any noise is coming from the solenoid. Post your model number for diagrams of parts. Model Number Locator I have similar problem. Get crushed ice even when switched to cubes. Solenoid? Accessible thru front of door? Kenmore 363.9537721.
