I have changed the water inlet valve, temperature control switch and ATC sensor and still no hot water.
I started with hot water filling the tub when cold water was selected. The washer is 13 years old but with a new transmission installed last year I was reluctant to give up on it. Now, I have close to the price of a new washer into it over the last two years.
Any suggestions other than replace the whole unit? Yes, the hot water is turned on and the filters at the water valve are clear.
Thanks, Dave
Check and see if 110-120 v is getting to the hot water valve terminals when it calls for power. I imagine it is not, which given everything else you have done suggests the timer is the problem. Be sure and check the wiring from the hot water valve to the timer to make sure it is not the problem.
