Approximately every 5-10 minutes there is a faint electrical snap coming from the white electrical connection on the left side of the compressor. From looking at your parts diagram we believe this is the “starting device kit, compressor” part # AP3885081. Does the snap noise indicate the switch is failing? Your parts diagram shows the white “starting device kit, compressor” but it looks different from the one actually on the compressor we have. I have attached a photo. Is the “starting device kit, compressor” part # AP3885081 the correct replacement part?jaystone attached the following image(s):
