lkgibbs
#1 Posted : Tuesday, September 20, 2011 6:45:00 AM(UTC)
lkgibbs
Dryer overheated then shut off. Replaced thermal fuse. It runs but still periodically overheats then shuts off. After a few minutes, it will restart. It doen'st do it all the time. Doesn't matter what the Temperature Switch is set on.
magician59
#2 Posted : Tuesday, September 20, 2011 7:39:45 AM(UTC)
magician59
A common cause of dryers overheating is restricted airfolw. Check the vent from the dryer, all the way to the outside of the house. Look for kinks (if you're using flex duct), or other restrictions, like clogs and animal nests.
If the air flows as strongly at the house vent outlet as it does at the dryer, you may have a bad cycling thermostat.
Part number: AP4038936
lkgibbs
#3 Posted : Tuesday, September 20, 2011 5:53:06 PM(UTC)
lkgibbs
Thanks for the info. When it first quit I took it apart and thoroughly cleaned everything, which it desparately needed. I only changed one thermal fuse. I'll try replacing all of them and see how that works.
Thanks again.
WED4815EW1 Dryer overheating? (Dryer Repair)
by Guest 4/16/2024 12:21:03 PM(UTC)
Kenmore gas dryer overheating and shutting down in permanent press setting (Dryer Repair)
by Actonite 8/14/2022 4:57:32 PM(UTC)
Whirlpool dryer overheating, replaced thermostats (Dryer Repair)
by rastoma 10/18/2017 6:29:27 PM(UTC)
Kenmore Dryer Overheating and weak (Dryer Repair)
by Cardiaccat 9/3/2017 9:25:50 AM(UTC)
Dryer Overheating When Not Running (Dryer Repair)
by Chris McCain 4/5/2017 8:06:45 AM(UTC)
Maytag Dryer Overheating (Dryer Repair)
by atem2144 10/28/2016 12:34:41 PM(UTC)
dryer overheating (Dryer Repair)
by dave3712 10/15/2016 8:16:37 AM(UTC)
Estate Dryer Overheating. I suspect hot air leaking from drum (Dryer Repair)
by Picklefall1 9/12/2016 8:13:23 PM(UTC)
Kenmore Dryer Overheating (Dryer Repair)
by atem2144 8/17/2016 1:41:31 PM(UTC)
by dadunn60 3/1/2016 9:43:04 AM(UTC)
by sfhutchi 2/28/2015 1:57:08 PM(UTC)
Whirlpool Dryer Overheating (Dryer Repair)
by TravisC 1/17/2015 11:13:36 AM(UTC)
by HawtDog 1/12/2015 1:59:21 PM(UTC)
Duet Dryer Overheating (Dryer Repair)
by Snarlybarley 11/20/2013 6:44:40 AM(UTC)
Dryer Overheating When Turned Off (Dryer Repair)
by Jeffshumaker 10/13/2013 4:27:05 PM(UTC)
