Frigidaire front load will not rinse and spin reliably. When it would not rinse and spin on regular wash, I switched to delicate and it was OK for a few loads, then failed. Back to regular wash worked once, then I had to manually tick off the cycle and it went to spin and rinse just fine. Will it get better if I keep tricking it? Looks like spin cycle is the weak link judging from other comments.
