darkmann
#1 Posted : Saturday, August 27, 2011 9:19:39 AM(UTC)
darkmann
Moved to a new place and the system will not complete any cycle. It PAUSEs and I have to unPAUSE by pressing the START/PAUSE button to continue cycle. It would run for maybe a minute, two, or even three and then pauses again. I have to continue un-pausing to finish wash. You can imagine how much of a pain this is. Like I said, it worked just fine at the house I moved from and the washer it replaces at the new place (Frigidaire also) worked just fine. What could be the problem? I thought plugged drain, but why didn't it affect the older washer? Thanks.
sidfink43
#2 Posted : Sunday, August 28, 2011 4:00:29 PM(UTC)
sidfink43
I cannot get your model number to come up, but if this is the basic front load Frigidaire you should have tech notes inside the lower service panel that will tell you how to do some testing and diagnosis. Focus on the control unit.
darkmann
#3 Posted: : Sunday, August 28, 2011 7:06:47 PM(UTC)
darkmann
Thanks. Where's the lower service panel?
sidfink43
#4 Posted : Monday, August 29, 2011 3:51:35 AM(UTC)
sidfink43
It is right below the door held on by two screws
darkmann
#5 Posted : Sunday, September 11, 2011 5:15:16 PM(UTC)
darkmann
Thanks very much. I figured out the problem - when the moving people installed at my new place, they forgot to turn on the water coming into the washer to full volume. Opened up the inlet flow and washer is now very happy.
