juneelkin
#1 Posted : Monday, August 22, 2011 9:57:01 AM(UTC)
juneelkin
Hello i have a roper drye r replaced drum rollers tension wheel drum felt front and rear. Makes a bad noise when you first start it up. Thanks with your help.
magician59
#2 Posted : Monday, August 22, 2011 9:59:06 AM(UTC)
magician59
If it's kind of a rumbling noise, and especially if it occurs on start-up, it is likely to be a loose blower fan.
Part number: AP2997251
Samsung Dryer eats up drum rollers (Dryer Repair)
by boyd0384 1/6/2019 10:09:21 PM(UTC)
Need to sweep timer switch to start dryer (Dryer Repair)
by jebstep 1/4/2019 8:17:56 PM(UTC)
Maytag Dryer blinking lights won't start (Dryer Repair)
by LRP116 12/15/2018 6:25:54 AM(UTC)
GE Adora Dryer Moisture Sensor Replacement (Dryer Repair)
by RedCoat999 12/14/2018 1:38:37 PM(UTC)
Bosch Nexxt Premium Gas dryer (Dryer Repair)
by logcabin1 12/5/2018 4:31:40 PM(UTC)
Electrolux dryer - long dry times (Dryer Repair)
by twinlabs 12/5/2018 7:58:01 AM(UTC)
dryer blower wheel replacement (Dryer Repair)
by lancehenley1 12/4/2018 11:42:59 AM(UTC)
Low heat on Whirlpool thin twin electric dryer (Dryer Repair)
by lotusTT 12/2/2018 4:06:08 PM(UTC)
GE Dryer replaced control board and all the lights are flashing (Dryer Repair)
by cjfordvt 12/1/2018 6:17:07 PM(UTC)
Dryer heats up but takes too long to dry (Dryer Repair)
by bear0729 11/13/2018 6:35:10 AM(UTC)
Electrolux Washer Dryer Combo (Dishwasher Repair)
by dhowe 11/10/2018 1:55:37 PM(UTC)
Dryer Model WED5000DW2 Need help on dryer door handle (Dryer Repair)
by tljohnsonrealtor@aol.com 11/1/2018 9:44:58 AM(UTC)
Dryer still not heating after new parts were installed (Dryer Repair)
by rclion0410 11/1/2018 8:48:03 AM(UTC)
Maytag Dryer Panel Lights Work But Won't Start (Dryer Repair)
by G-Daddy 10/31/2018 4:37:11 PM(UTC)
Frigidaire Gas Dryer Shuts Off After Less Than A Minute Run Time (Dryer Repair)
by hooter726 10/23/2018 11:54:54 AM(UTC)
