bobbyh4dkeys
#1 Posted : Monday, August 22, 2011 7:50:55 AM(UTC)
bobbyh4dkeys
What is the normal COLD reading in ohms for the temp sensor in the right front element. The electronic controll seems to be defective however I saw a post that indicated a defective temp sensor may be the problem.
Jenn-Air dual wall oven temp sensor replacement (Oven Repair (including Ranges and Cooktops))
by jgmtfia 8/8/2017 1:20:49 AM(UTC)
Code F3E2 Water Temp Sensor Error (Washer Repair)
by ldbeng@verizon.net 4/14/2017 4:59:25 PM(UTC)
Weird Temp Sensor issue (Oven Repair (including Ranges and Cooktops))
by YooHoo 2/21/2017 5:12:58 AM(UTC)
Samsung RF4267HAWP freezer temp sensor (Refrigerator & Freezer Repair)
by hndrcks 9/6/2014 3:40:14 AM(UTC)
GE Error F3, it's not the oven temp sensor (Oven Repair (including Ranges and Cooktops))
by klavender1 8/28/2014 5:46:22 AM(UTC)
Replaced Temp sensor, still no heat (Oven Repair (including Ranges and Cooktops))
by Hypnocrip 2/21/2014 12:34:27 AM(UTC)
GE Oven Temp sensor replacement (Oven Repair (including Ranges and Cooktops))
by CK_GE_Temp 12/12/2012 9:42:05 AM(UTC)
E2 F3 error after replacing temp sensor (Oven Repair (including Ranges and Cooktops))
by kenh99 10/3/2012 12:29:22 PM(UTC)
Temp sensors (Oven Repair (including Ranges and Cooktops))
by patrickemb 7/9/2012 11:51:15 AM(UTC)
Intermittent overheating with _new_ temp sensor & ERC (Oven Repair (including Ranges and Cooktops))
by jkdean 10/31/2011 3:04:20 PM(UTC)
Thermostat and Temp Sensor Replacement (Refrigerator & Freezer Repair)
by tnjanderson 8/19/2011 5:26:13 AM(UTC)
Magic Chef F3 error code even after temp sensor replacement (Oven Repair (including Ranges and Cooktops))
by ponderitsome 7/21/2011 3:46:26 PM(UTC)
Oven temp sensor - ohm readings (Oven Repair (including Ranges and Cooktops))
by clucktrent 4/29/2011 1:47:02 PM(UTC)
need help in replacing temp sensor (Refrigerator & Freezer Repair)
by bambooma 4/13/2011 11:16:36 AM(UTC)
Thermal link & High Temp sensor (Dryer Repair)
by Abnormal Norman 5/24/2010 7:23:44 PM(UTC)
