2 Pages12>
worccx
#1 Posted : Wednesday, August 17, 2011 1:02:21 PM(UTC)
worccx
The oven won't lite I can hear what sounds like gas and the click of the liter but nothing. Stove top and broiler works fine. I played around back like unplugging and plugging back in and tapping in back then it would lite several times but now nothing, oven won't lit at all.
I figured it out once I learned how to read. Serial date code once I figured that out It was as simple as replace part and turn on.
#2 Posted : Wednesday, August 17, 2011 2:49:10 PM(UTC)
Remove the oven floor and the flame spreader. Check how good is the spark at the Bake burner igniter while the control calls for Bake. Post the results.
Here are the breakdown diagrams and Replacement parts for WHIRLPOOL WFG371LVS1 30" GAS FREESTANDING SELF CLEAN RANGE SEALED BURNER | AppliancePartsPros.com
worccx
#3 Posted : Wednesday, August 17, 2011 5:07:08 PM(UTC)
worccx
Thanks it might be the weekend before I can get to it.
Thanks again.
#4 Posted : Wednesday, August 17, 2011 9:05:15 PM(UTC)
worccx
#5 Posted : Thursday, August 18, 2011 4:55:48 AM(UTC)
worccx
Gene:
I don't see any spark from the igniter, I was able to lite it with a liter. Do you think I need igniter harness, oven igniter or both?
Thanks,
Chuck
#6 Posted : Thursday, August 18, 2011 2:21:04 PM(UTC)
Originally Posted by: worccx Go to Quoted Post
...I was able to lite it with a liter...
Chuck,
Did it stay lit?
Sounds like the problem is a bad spark module.
- The spark module Part number: AP3672576
worccx
#7 Posted : Friday, August 19, 2011 1:29:37 AM(UTC)
worccx
Gene:
Yes it stays lit, I left it lit for 5 min before turning off. Does this board take any specail tools to replace and is it easy to get to?
Thanks,
Chuck
#8 Posted : Saturday, August 20, 2011 5:05:34 PM(UTC)
No, it does not need any special tools and the new part comes with the instructions.
worccx
#9 Posted : Friday, August 26, 2011 5:23:17 AM(UTC)
worccx
Gene:
Confused and lost. I've got the board installed and removed and taped off the red wire from the original board but can't locate the jumper to remove. It says: "3. A jumper located at the power cord connection must be removed. (This connection is located at the right rear area of the storage drawer/warming drawer compartment)" I have the storage drawer removed and don't see anything that makes sense. Can you give me any further instructions.
Thanks,
Chuck
worccx
#10 Posted : Tuesday, August 30, 2011 2:44:49 PM(UTC)
worccx
No longer confused. I figured out how to read, it's the serial date code once I researched that on line my oven does not fall under that so all I had to do was replace part and turn on. Very simple for you guys but not for a novice like me.
2 Pages12>
