I have a Kenmore Calypso washer Model No. 110.22082102 Product type 170 Serial No. CM5013566 Purchased 1-11-03. It will run through the first full cycle with no problem. The second cycle will run okay until it reaches the rinse mode, then as the water is coming in the unit will stop for 3-5 seconds and then tries to start again for 3-5 seconds and continues indefinitely in this pattern and the timer has stopped counting down. I can raise the lid and let it sit. After it sits for an hour or so it will start and finish the load okay. I have replaced the pump motor and capacitor but that did not fix the problem. Can you please help me?
First off I have never worked on one of these so cannot be of much help. Hopefully someone else who has will jump in. I can provide you with a service manual which should be close. https://secured.whirlpoo...4632a4/$FILE/8178010.pdfSounds like the main motor is overheating for some reason. Perhaps the diagnostics will help. |
THIS FORUM IS DEAD!!!!!!! |
I am having the same issue. Hesitates, will work after some time left off. Passes all diags. Replace motor control board and issue persists. Help??!?
