my washer spin cycle does not extract water on the last spin. The door lock light does not come on. you can hear it washing but it wont spin.
The first thing you are going to want to do is check in the drain lines inside the machine and the pump for obstructions. I suspect the problem is with the control board, however. Look at it and see if you see any burn't spots.
If so, given the history of this machine and its age a replacement is in order.
