carmenc
#1 Posted : Monday, August 8, 2011 8:49:31 AM(UTC)
carmenc
my washer spin cycle does not extract water on the last spin. The door lock light does not come on. you can hear it washing but it wont spin.
sidfink43
#2 Posted : Tuesday, August 9, 2011 6:03:42 PM(UTC)
sidfink43
The first thing you are going to want to do is check in the drain lines inside the machine and the pump for obstructions. I suspect the problem is with the control board, however. Look at it and see if you see any burn't spots.
If so, given the history of this machine and its age a replacement is in order.
Whirlpool washer spin cycle towels only problem (Washer Repair)
by kylo67 10/1/2023 5:54:44 PM(UTC)
Speed Queen Washer Spin Cycle (Washer Repair)
by phaffy12 7/21/2022 6:23:17 AM(UTC)
GE washer spin cycle noise (Washer Repair)
by Tcmancan 11/30/2018 6:01:12 PM(UTC)
Washer spin cycle (Washer Repair)
by wwm0322 2/10/2018 11:07:31 AM(UTC)
Washer spin cycle problem (Washer Repair)
by td307 12/30/2015 11:17:13 AM(UTC)
thintwin washer spin cycle (Washer Repair)
by toothwater 4/11/2015 6:35:17 AM(UTC)
GE Washer Spin Cycle not Working (Washer Repair)
by jmoconn 3/31/2015 6:28:49 AM(UTC)
Washer spin cycle does not engage on its own (Washer Repair)
by deftones355 1/28/2015 11:33:40 AM(UTC)
Whirlpool Washer spin cycle wobble (Washer Repair)
by uruiamme 5/9/2014 3:55:11 AM(UTC)
help with GE washer spin cycle noise (Washer Repair)
by chase0555 1/25/2014 7:09:00 AM(UTC)
by Jheel34 1/10/2014 2:41:04 PM(UTC)
Washer spin cycle out of balance after replacing basket drive (Washer Repair)
by ms031317 11/16/2013 9:39:08 PM(UTC)
Admiral Washer Spin Cycle problem (Washer Repair)
by nckomorowski 10/21/2012 8:15:37 AM(UTC)
May tag washer spin cycle problem (Washer Repair)
by C.ketcham 10/14/2012 10:38:06 AM(UTC)
Maytag Neptune Washer Spin Cycle Noise (Washer Repair)
by jayjaysin 8/19/2012 6:14:50 AM(UTC)
