amills02
#1 Posted : Saturday, August 6, 2011 3:44:45 PM(UTC)
amills02
I bought this wash cheap from a lady that said it worked fine other than it won't agitate. I found the problem with that and now its fine. Now it seems that I have a new problem. Randomly the washer will just quit mid cycle leaving water in the bottom or not spinning. I've checked the drain pump and it seems to be fine. The only other thing I can think of would be the control panel. I hate to put the money into that though if its not the problem, so thats why I'm looking for advice. Another wierd thing is the water temp is off. If I put it on cold cold it comes out hot. I have to turn the knob way down to warm to get cold. I put it into field test mode and if I did it correctly it looks like it has a code set for Thermistor, flood, and slow pump. Flood and slow pump don't make much sense to me but the Thermistor kinda goes along with the water temp being off. Could it all be the control panel? I'm out of ideas.
