AppliancePartsPros.com
Appliance Repair Help
Washer Repair
washer won't change cycles after changing timer
i just ordered a new timer for my washer and changed it out tonight. however, the washer still won't change cycles. any other suggestions?
Originally Posted by: holli i just ordered a new timer for my washer and changed it out tonight. however, the washer still won't change cycles. any other suggestions? Holli, If you installed the proper timer, Part number: AP3755885
And you're sure the wire harness connector is properly attached, and locked in place on the timer. The problem would be in the motor or the wiring to the motor, Part number: AP3081301
Washer Repair
