I am looking to replace impeller drive sleeve. Part slides onto shaft of drive motor then snaps into impeller inside machine. Not looking to put a complete motor kit into machine. Part is plastic 2 1/2 inches long and 5/16 in diameter. thanks for any help
Originally Posted by: lryan03@snet.net  I am looking to replace impeller drive sleeve. Part slides onto shaft of drive motor then snaps into impeller inside machine. Not looking to put a complete motor kit into machine. Part is plastic 2 1/2 inches long and 5/16 in diameter. thanks for any help Refer to this other string: http://forum.appliancepartspros...otor-shaft-impeller.html
