The problem is no power to oven. A dark oven. Breaker ok , power to dist block ok, loose white input wire at block, tightened still no power, buss fuse checked ok....All this happened after lower oven clean cycle, brown outs and code pf .d=27 kitchen aid superba micro/oven combo mod kems378gss2 Dec. 2000 please help!
