Hi, I have a Whirlpool cooking range... and all of a sudden when I try to light it, I don't hear any clicks. However, I can turn it on manually with a match. I thought it was probably the spark module. I go the part number 8273977, and replaced it.. however still no clicks. Some other posts have been posted regarding cutting the red wire etc.. but not sure if mine falls under that category becasue the instruction sheet provided talks about code date range, which makes no sense to me. My serial number is RP2912822
Any ideas? Today it just started working at random. But I know itnwill stop again. It has happened many times before.
