My InSink Erator will not work and only hums. It drains very very slow.
I can turn the blades using the special tool inserted in the bottom. It turns easily in either direction. The reset button does not help.
I also tried using Drano just for kicks, but that didn't help.
I am thinking the only thing left is to replace the unit, but I don't understand why it would still just hum if the blades are turning ok.
Anything else I can try or is it time for a new one?
