Washer was delivered. Delivery person went to test drain cycle. There was a clicking noise like a selanoid switch going in and out. Delivery person said it may be due to cold as the temp was 5 degrees. Tried washer 15 minutes later, worked perfect. Done approx. 15 loads, no clicking noise. Washer seems to work. Called Sears. They said they would replace it with a new washer. Could it have been the extreme cold and would you suggest getting another one or just keeping it since it is working perfect?
Get it replaced, they may have dropped it when shipping and the damage may be hard to figure out. With the next washer, leave it alone for several hours to let any ice in the pump melt.
