kretz-vern
#1 Posted : Tuesday, June 14, 2011 8:38:34 AM(UTC)
kretz-vern
My electric dryer was purchased in 8/2010 and it currently is not operating properly. When it starts a cycle, it runs for a short time (10-15 mins) and then the top of the dryer is very hot, and it will stop and trip the circuit breaker in the panel box. The breaker is not hot to the touch, and if you reset it and start the dryer, then it will usually complete the drying process. Anytime I try to dry something like denim materials, it takes at least 2-3 cycles of drying for them to get completely dry.
Thank you for any suggestions you can make.:mad:
#2 Posted : Wednesday, June 15, 2011 2:54:01 AM(UTC)
Was thanked: 10 time(s) in 10 post(s)
Here are the parts.
Replacement parts for AED4475 models | AppliancePartsPros.com
Check the heating coil.
Unplug the unit and both wires to the coil.
Check it with a meter, should be around 10 to 12 ohms.
Then check from each side of the coil to the case/frame, both should be infinite ohms (open). If not the coil may have sagged or broken and is touching the case. This can cause it to run on high and pull excessive current.
4. When you start always short the meter leads together. This will tell you that the meter is working and if there is any 0 offset.
