When drain cycle begins the drum does not spin. onece I push the timer swith in and pull out the drum begins to spin. Was told that it was the timer switch so replaced but still does the same thing. also replaced the lid switch but same result. Any thoughts?
Timer is supposed to stop briefly during spin to allow the neutral drain tranny to engage spin mode. If no stop, you still have a bad timer.
You don't think she could be possibly seeing the begining's of a clutch problem? Tom ApplianceEducator.com
