I have a Modern Maid Wall Oven, Convection Slo Cook and you need to hold any one of the setting buttons in (bake, convection bake, etc.) on the control center numerous times or for long periods of times for the oven to finally respond. It will start at preheat temp of 170 degrees for about 15-30 seconds then will shut off by itself. After numerous tries and holding in buttons for about 5 minutes the oven will finally start working. Any Ideas.
Thanks,
Dale.
Dale,
Unfortunately all controls for this model have been discontinued and are no longer available.
