I determined that the door switch doesn't have continuity for the open/light on/dryer off, close/dryer run/light off functions. Unfortunately I'm not sure which 3 separate wire sets go to which posts on a new switch replacement. I need a wiring diagram for MDG5500AWW Thanks, Calvet
