Oven lights initially. Intermittently fails to relight. I can hear the relay in the control panel pick and the ignighter glows. Then the relay drops and the ignighter cools. A few seconds the process repeats. Once it fails to relight I can hit clear on the control panel and reset for a bake temp and it will start. When it needs to restart the cycle starts again.
Control panel or ignighter?
SN # ZZ216749P
Thanks,
Warren
