lqking
#1 Posted : Tuesday, February 17, 2009 11:35:59 AM(UTC)
lqking
Have the model mentioned. The front RT burner does not light anymore. I can hear the igniter clicking and see the spark but no gas is getting to the igniter. Any ideas on that part /s need to be replaced, part numbers etc. ? Most parts companys are of no help since I don't sspecifically know which part to replace. Any help would be appreciated.
Thanks!
LK
jdappl07
#2 Posted : Tuesday, February 17, 2009 6:38:17 PM(UTC)
jdappl07
first thing i would is thoughly clean the burner head and parts that gas flows through if that didnt work can you hear gas coming on if not it would be the valve
Thermador Cooktop Ignition Problems (Oven Repair (including Ranges and Cooktops))
by HotPepperFan 1/15/2016 10:56:01 AM(UTC)
Burner problem with Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by philw007 1/20/2015 8:35:01 AM(UTC)
by LMK 8/18/2013 2:28:22 PM(UTC)
Thermador Cooktop Griddle Doesn't Heat Properly (Oven Repair (including Ranges and Cooktops))
by HotPepperFan 5/15/2013 12:36:04 PM(UTC)
thermador cooktop problems (Oven Repair (including Ranges and Cooktops))
by billg87 1/12/2013 5:57:14 PM(UTC)
Remove front panel of Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by hloos 12/18/2012 1:57:11 PM(UTC)
Thermador Cooktop Spark Module (Oven Repair (including Ranges and Cooktops))
by randydodd 10/26/2012 2:50:16 PM(UTC)
thermador cooktop halogen burner partially working (Oven Repair (including Ranges and Cooktops))
by judith w 10/20/2012 5:00:09 PM(UTC)
Weak Spark on Thermador Cooktop (Oven Repair (including Ranges and Cooktops))
by cwilliamrose 6/5/2012 11:53:46 AM(UTC)
One igniter stopped working on my Thermador cooktop (Oven Repair (including Ranges and Cooktops))
by ingas 3/25/2012 9:25:28 PM(UTC)
Thermador Cooktop XLO Burners (Oven Repair (including Ranges and Cooktops))
by gimidlin 3/20/2012 8:22:44 AM(UTC)
by rw777 2/17/2012 8:36:31 AM(UTC)
Thermador cooktop can't remove burner (Oven Repair (including Ranges and Cooktops))
by ckrash 2/15/2012 3:36:43 PM(UTC)
need help with Thermador cooktop - won't light (Oven Repair (including Ranges and Cooktops))
by larryzipper 2/3/2012 1:01:51 PM(UTC)
Thermador cooktop:how to replace the plate piece (Oven Repair (including Ranges and Cooktops))
by raquel@khorram.us 12/13/2011 10:19:13 AM(UTC)
