jlozon
#1 Posted : Tuesday, May 31, 2011 4:22:36 PM(UTC)
jlozon
have no air flow between freezer and refridge side. took inside cover off and found evap motor not running. is this a part that will normally fail.should i replace motor or is this possibly another problem causing fan not to run.
#2 Posted : Tuesday, May 31, 2011 4:41:16 PM(UTC)
Replacement parts for WHIRLPOOL GD5PHAXMS10 REFRIGERATOR | AppliancePartsPros.com
Yes fans do go bad.
If you have a meter check for 120 volts going to the fan.
If you have 120 volts and the fan does not turn it is toast.
Frigidaire Evaporator Fan (Refrigerator & Freezer Repair)
by KevN1974 4/13/2024 11:03:34 AM(UTC)
Monogram side-by-side not cooling - Ice builds up on Evaporator Fan (Refrigerator & Freezer Repair)
by 95ireland 3/11/2024 6:22:51 PM(UTC)
Continuously running evaporator fan (Refrigerator & Freezer Repair)
by gjgogol 2/26/2024 6:47:30 AM(UTC)
evaporator fan runs all the time in FF compartment (Refrigerator & Freezer Repair)
by Guest 8/17/2023 6:27:55 AM(UTC)
Crosley Freezer Evaporator Fan (Refrigerator & Freezer Repair)
by CP1 9/25/2022 1:16:25 PM(UTC)
How do I access GE Evaporator Fan, coils, thermistor, etc (Refrigerator & Freezer Repair)
by Yari 8/4/2022 1:48:47 PM(UTC)
samsung rf31fmesbsr evaporator fan voltage question (Refrigerator & Freezer Repair)
by jimmye4golf 7/20/2022 8:30:42 PM(UTC)
Evaporator fan only running (Refrigerator & Freezer Repair)
by jesus freak 5/17/2022 2:40:35 PM(UTC)
Evaporator fan blowing down (Refrigerator & Freezer Repair)
by Guest 1/18/2022 8:46:06 AM(UTC)
Kenmore evaporator fan cycles on and off (Refrigerator & Freezer Repair)
by kelly.kendrick@me.com 1/16/2022 1:43:06 PM(UTC)
Whirlpool WRX735SDBM00 fridge evaporator fan always on (Refrigerator & Freezer Repair)
by matmat 12/3/2021 8:25:59 PM(UTC)
U-Line Evaporator Fan Not working (Refrigerator & Freezer Repair)
by roscoej 10/5/2021 7:24:11 PM(UTC)
Noisy evaporator fan on subzero 650 (Refrigerator & Freezer Repair)
by DoctorG 8/5/2021 6:41:45 PM(UTC)
If you're evaporator fan constantly cycles on and off and never shuts down (Refrigerator & Freezer Repair)
by Guest 7/7/2021 10:42:26 PM(UTC)
Sub-Zero evaporator fan direction reversed (Refrigerator & Freezer Repair)
by just_phil 6/24/2021 9:21:44 PM(UTC)
