loco47
#1 Posted : Monday, May 30, 2011 12:53:08 PM(UTC)
loco47
OK...Have Disassembled Washer to Inspect cause(s) of Water Leaking during Fill & Spin Cycles.
Have Removed "PumP" which is attached to Two Hoses. This was leaking upon Inspection & before removing Hoses...however, I cannot see Any problems with the Pump Casing?
Also, upon removing Cabinet...there was Below the Pump described above, a Plastic Sleeve, if you will, that I've No Idea how it may append to the Pump??? I'm sure it does!
Part#'s are: Pump 8559389 ASS'Y; 3352293 WPI
Sleeve: 8539874
Once again...thank you kindly!
loco47
magician59
#2 Posted : Monday, May 30, 2011 12:56:24 PM(UTC)
magician59
If the pump was leaking, there is no other repair than to replace it.
Part number: AP2907492
loco47
#3 Posted : Monday, May 30, 2011 1:22:37 PM(UTC)
loco47
YUP...Mr Magician59! That's the badboy...But, can you please expound regarding the "Sleeve" I had mentioned? It was lying upon the floor Directly Below the Pump...I can only assume (mistake!) that the Sleeve belongs Somehow Affixed to the Pump Body???
Thanks again,
loco47
loco47
#4 Posted : Monday, May 30, 2011 2:38:05 PM(UTC)
loco47
Ah...I was correct saying It's a Mistake to Assume! The Sleeve previously described is, in fact, a SudsShield that goes on back of machine; on Rt side...Somehow!
Regards,
loco47
Whirlpool Duet MDL# WWF8400TW02 New Drain Pump (Washer Repair)
by 1Oskydoodle! 3/30/2024 10:30:29 AM(UTC)
Whirlpool heat pump dryers (Dryer Repair)
by Aptmtncguy 1/19/2024 3:44:50 PM(UTC)
Siemens dishwasher pump keeps running (Dishwasher Repair)
by Fweigel 12/30/2023 4:35:28 AM(UTC)
Need help to find pump for bosch wfmc4300uc/01 (Washer Repair)
by revox 11/25/2023 8:26:21 AM(UTC)
Bosch ventless dryer sump pump not working (Dryer Repair)
by mdavidson 11/18/2023 2:22:57 AM(UTC)
Kitchenaid dishwasher pump? (Dishwasher Repair)
by Guest 6/11/2023 10:15:41 AM(UTC)
Rheem RQNJ-A048JK000 heat pump (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 5/16/2023 7:10:38 AM(UTC)
GE GTW330ASK1WW circulator pump and spinn test just does nothing (Washer Repair)
by tommalia@ttdsinc.com 3/10/2023 3:41:31 PM(UTC)
Noisy LG Drain Pump (Washer Repair)
by Guest 1/13/2023 3:19:30 PM(UTC)
drain pump on lid locked (Washer Repair)
by Randero 7/6/2022 5:32:07 AM(UTC)
Maytag 5500 drain/pump issues (Washer Repair)
by mlp141 6/26/2022 7:06:24 PM(UTC)
Whirlpool Dishwasher Won't Drain Completely, I hear Pump Running... (Dishwasher Repair)
by Guest 4/18/2022 5:39:50 PM(UTC)
Pump for a Kenmore 3.5 super capacity (Washer Repair)
by Guest 4/17/2022 10:34:55 AM(UTC)
Quiet partner buzzing while pumping (Dishwasher Repair)
by Guest 3/10/2022 9:03:14 AM(UTC)
LG Washer Drain Pump Noise (Washer Repair)
by Guest 1/28/2022 8:06:10 AM(UTC)
