OK...Have Disassembled Washer to Inspect cause(s) of Water Leaking during Fill & Spin Cycles.
Have Removed "PumP" which is attached to Two Hoses. This was leaking upon Inspection & before removing Hoses...however, I cannot see Any problems with the Pump Casing?
Also, upon removing Cabinet...there was Below the Pump described above, a Plastic Sleeve, if you will, that I've No Idea how it may append to the Pump??? I'm sure it does!
Part#'s are: Pump 8559389 ASS'Y; 3352293 WPI Sleeve: 8539874
Once again...thank you kindly!
loco47
YUP...Mr Magician59! That's the badboy...But, can you please expound regarding the "Sleeve" I had mentioned? It was lying upon the floor Directly Below the Pump...I can only assume (mistake!) that the Sleeve belongs Somehow Affixed to the Pump Body???
Thanks again,
loco47
Ah...I was correct saying It's a Mistake to Assume! The Sleeve previously described is, in fact, a SudsShield that goes on back of machine; on Rt side...Somehow!
Regards,
loco47
