I've been in a rental for a year and just noticed the whirlpool Princess series was leaking water. I remove the veg drawers and forund the bottom of frig full of water. Can any one tell me where it's coming from?
The drain tube from the freezer to the drip tray under the unit is probably clogged. The water created during defrost then runs into the fresh food section instead of down to the drip pan. |
THIS FORUM IS DEAD!!!!!!! |
Originally Posted by: holyroman1  I've been in a rental for a year and just noticed the whirlpool Princess series was leaking water. I remove the veg drawers and forund the bottom of frig full of water. Can any one tell me where it's coming from? Check drain line from freezer section to see if it's clogged.
Thank you i will try that
