On the ptc, i have ohmed the switch out and reads nothing, i have 110 volts going to the wax motor.could this be a bad switch.
The door switch and the speed/motor control board are the traditional problems on this model.
Use the tech notes you should find inside the lower service panel to try and check things out.
