My dreyer wouldnt time out so I replaced the timmer, the timmer will work on cool down cycle but not on regular dry time. Could it be a thermostat? If so which one? Or should I be looking somewhere else?:confused:
I would recommend to clean the dryer vent line all the way through the vent outlet and replace the vent hose behind the dryer.
