The machine is leaking water during the rinse and spin cycle and it is not coming out of the hose that leads to the outside drain. It seems to be coming from under the machine, any ideas on where to start to find where the problem is at?:mad:
Daniel
Daniel,
Looks like this a laundry center with the dryer on top of the washer. Remove the washer front panel and you'll be able to watch all parts inside and locate the water leak.
Remove the two screws on the bottom of the front panel, slide it down and pull it out.
