Hazel55
#1 Posted : Wednesday, April 27, 2011 2:44:41 PM(UTC)
Hazel55
Washing machine will not spin just drain everything else works. What is wrong
magician59
#2 Posted : Wednesday, April 27, 2011 5:31:05 PM(UTC)
magician59
The first and easiest check to make (if the machine drains) is the motor coupling. Look under the machine, in the center front. If you see shreds of black rubber and/or white nylon, that would be a good indication the coupling's the culprit.
If the machine also won't drain, check for a bad lid switch.
whirlpool washing machine will not spin out everytime (Washer Repair)
by rdgiles1 4/16/2013 6:50:00 AM(UTC)
washing machine will not spin when loaded but does when empty (Washer Repair)
by garyg53 2/11/2012 12:46:14 PM(UTC)
Washing Machine will not spin or agitate (Washer Repair)
by BJT 1/11/2012 1:09:03 PM(UTC)
my washing machine will not spin (Washer Repair)
by christian97394 4/24/2011 4:26:33 AM(UTC)
Maytag Washing machine will not spin water out (Washer Repair)
by schrades712 10/8/2010 5:16:35 AM(UTC)
kenmore washing machine will not spin (Washer Repair)
by Rito 4/19/2010 4:21:57 PM(UTC)
by robins 11/3/2009 2:30:31 PM(UTC)
Washing machine will not spin drain (Washer Repair)
by tbarry 9/5/2009 11:04:54 AM(UTC)
Washing machine will not spin during rinse cycle (Washer Repair)
by crookster 4/24/2009 1:16:20 PM(UTC)
ge washing machine will not spin or agitate (Washer Repair)
by m-fuson 3/8/2009 10:49:45 AM(UTC)
Washing Machine will not spin in the spin cycle (Washer Repair)
by totoro00us 12/23/2008 11:55:25 AM(UTC)
