My GE side by side m# GSL25JFAPBS is too warm in freezer compartment, around 32 F. I took the back cover off and found the lower 3rd of the evaporator coils frosted over and the upper portion with no frost (see pic). I ohmed the defrost heater and found 21 ohms, assume it is good. I checked the defrost thermostat and it stayed closed during testing in a cup of ice and blowing a hair dryer over it out of circuit, so I assumed it is bad. The evaporator fan is blowing well. I got a new thermostat today and installed it but after about 3hrs the symptoms are the same. Could use some advise on what to do next. Thanks MrFrisco attached the following image(s):
After running empty for 24 hrs the temp is down to 19F in freezer but I don't think this is low enough. Anyone have any ideas?
Here your parts. I think the "AP" in the model number should be PA. Replacement parts for GSL25JFAPBS models | AppliancePartsPros.comLooks like you may have a low freon problem. http://www.applianceaid.com/frig_notcold.htmlTake a look at the example pictures in the 5th paragraph. I would check that the condenser/compressor fan is running and that the condenser coils are clean. If low freon is the case then the repair will be expensive as you will need a pro. Finding and repairing a leak can be time consuming. Also there is no guarantee of a long term fix. In most cases it makes more sense to put those dollars towards a new unit. Check the purchase date as the sealed system should have a 5 year warranty, |
THIS FORUM IS DEAD!!!!!!! |
