wils0nc
#1 Posted : Friday, April 15, 2011 9:52:20 AM(UTC)
wils0nc
I was not getting ice in the freezer. The temp for the freezer is 20 degrees F, and the fridge is 40 degrees F. The freezer setting was 4 and I turned it to 1. The fridge setting was 4 and I turned it to 2. The freezer now is occasionally making batches of ice. I believe the freezer needs to be colder. Other than cleaning the dust from under the unit what should I do? Thank you.
#2 Posted : Sunday, April 17, 2011 3:53:11 AM(UTC)
Replacement parts for SQD25NBW models | AppliancePartsPros.com
If the compressor is cycling on/off and the evaporator and condenser fans work. I would say it is a control problem Item 30 in Section 17.
Samsung French Door Refrigerator freezer not cold enough (Refrigerator & Freezer Repair)
by Sh@wn 1/5/2022 6:50:52 PM(UTC)
Dual evap fridge , Freezer not cold enough. (Refrigerator & Freezer Repair)
by max57 10/1/2021 9:05:00 AM(UTC)
bottom freezer not cold enough (Refrigerator & Freezer Repair)
by Guest 7/28/2021 6:36:45 AM(UTC)
Freezer not cold enough, Refrigerator fine (Refrigerator & Freezer Repair)
by kjames1234 4/27/2020 3:48:04 PM(UTC)
GE (Samsung) PFSS6PKXBSS freezer not cold enough (Refrigerator & Freezer Repair)
by rrreinig 9/28/2019 8:04:28 AM(UTC)
Fridge OK Freezer Not Cold Enough (Refrigerator & Freezer Repair)
by Jonrg 8/12/2017 10:38:47 PM(UTC)
Freezer not cold enough (Refrigerator & Freezer Repair)
by stephan28 6/6/2017 3:40:52 PM(UTC)
by projvw18t 11/3/2016 9:38:11 AM(UTC)
by edmiller 9/1/2016 8:32:25 AM(UTC)
[Samsung] Freezer not cold enough, door says it is? (Refrigerator & Freezer Repair)
by IncredibleHat 9/30/2015 6:24:20 AM(UTC)
Frig and freezer not cold enough (Refrigerator & Freezer Repair)
by themayhews 9/24/2015 9:57:47 AM(UTC)
by billpulsipher@gmail.com 8/28/2015 11:25:19 AM(UTC)
Kenmore fridge cold freezer not cold enough (Refrigerator & Freezer Repair)
by Jasonywu 8/6/2015 2:05:17 PM(UTC)
by Suzalasue 5/28/2015 6:08:45 AM(UTC)
by wnorton 1/27/2015 3:21:20 PM(UTC)
