FRED BOUMAN
#1 Posted : Friday, April 15, 2011 3:49:40 AM(UTC)
FRED BOUMAN
On My Refer In The Fresh Food Compartment,on The Bottom Is A Quick Chill Section Located Below Fresh Food Coil. Where This Unit Mounts And Meets The Dividing Wall Between The F.f And Freezer There Is Frost Building Up, Then Melting And Then Pooling Under Vegetable Bin. I Would Like To Know Why This Is Happening, The Temps Are Good And The Gaskets Are Good. I Know That In This Section There Is A Fan Motor And Damper Assembly And Sensor Could There Be Something Wrong There?i Can't Get A Straight Or Correct Answer From G.e. Is There Someone Out There With Experience On This G.e. Profile Artica Need Help, Thanks, Fred.
